I am planning to purchase an L3560 LE very soon, but I am trying finalize which options I want to purchase with the tractor. I have already decided that I will add the third function kit to the front, but I'm not very clear on the details of top n tilt / rear hydraulics.
I understand the basics - that if I have top n tilt, I can lift and tilt a 3 point attachment such as a box scraper. Where I am confused is the use of a double acting valve vs the float valve and which is better for different scenarios. I understand if you set a valve to the float position, a box scraper or mower can move freely on the ground. When you add a float valve, is it one of the two valves on the top n tilt, or do both of those need to be double acting valves and then a third valve is added for the float funciton? Can 2 or more valves be floating?
Sorry if these are basic questions. The more I read, the more confused I get. I am trying to decide between 2 and 3 valves and what type I should get. The dealer is offering me a discount on the rear remote kit and cylinders if I purchase with the tractor, but I'm not sure which (if any) I should include. I won't be doing any mowing, but I will be building and maintaining sections of road and a long drive on 40 acres. I was thinking the float function may come in handy, but wasn't certain.
thanks,
Nick
thanks,
Nick
