Hi-
I think I'm going to tackle adding an auxiliary fuse block to my BX and was wondering if this would work for a block:
https://www.amazon.com/6-Way-Blade-...s=automotive+fuse+block&qid=1579884703&sr=8-7
I know the factory block uses mini-blade fuses and the one above seems to use standard fuses; is that a problem. Would a 30-amp relay be sufficient for this?
Obviously I'm a noobie here, so any additional info. that may be helpful would be appreciated.
Thanks for any help!
