Adding Aux Fuse Block to BX
bluedunn
BX1860, FEL, MMM, Heavy Hitch Back Plow Blade
Aug 29, 2019
304
40
Thetford, VT
Hi-
I think I'm going to tackle adding an auxiliary fuse block to my BX and was wondering if this would work for a block:
https://www.amazon.com/6-Way-Blade-...s=automotive+fuse+block&qid=1579884703&sr=8-7
I know the factory block uses mini-blade fuses and the one above seems to use standard fuses; is that a problem. Would a 30-amp relay be sufficient for this?
Obviously I'm a noobie here, so any additional info. that may be helpful would be appreciated.
Thanks for any help!
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
Hi-
If it fits it will work fine. A fuse is a fuse for the most part.
Bigger question? What do you plan to run with it?
Can the BX electrical output handle it, what model?
bluedunn
Aug 29, 2019
304
40
Thetford, VT
Planning on running a battery meter, a couple of LED lights...that's about all I can think of (for now). Not a ton really.
bluedunn
Aug 29, 2019
304
40
Thetford, VT
You should have no problem then.
I recently added a couple LED's to my Canopy and was surprised to find out the 120W LED's (as advertised) only drew about 20W in reality.
https://www.amazon.com/dp/B07B9SS2FB/ref=cm_sw_em_r_mt_dp_U_mxZkEbT9RRFJF
I have found it is a good idea to actually test them.
Nice!
Do you know what gauge of wire I should use? 10-gauge? I have 14 coming off of the fuse block. Sorry, I'm still learning about this but also want to get going on the install :)
5,257
1,046
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
