B2650 black diesel exhaust
eliot3b4
Kubota B2650
Nov 7, 2019
36
Eliot, Maine
I was snowplowing with the B2650 and the front snow blower. Everything was great then I went to clean up the end of our driveway and all of a sudden thin black exhaust. No matter what I did, the black exhaust continued.
I've added some additive I keep on hand and I think it is helping.
Any thoughts on why this is happening?
I now have 10 hours on my machine.
Can the fuel air mixture be too rich? a y other thoughts
SDT
multiple and various
Apr 15, 2018
3,086
927
SE, IN
Re: B23650 black diesel exhaust
How many hours on the tractor?
Have you checked/cleaned/replaced the air filter?
Snow in the air inlet?
SDT
conropl
L3560 HSDC
Oct 17, 2016
233
West Michigan
With only 10 hours on the tractor, the first thing I would check is the air intake, filter canister and filter. As said above, it is probably clogged with snow. If it is, clean it out, and be sure to thaw out the filter and dry it. It has been know to happen when snow blowing, and I believe that tractor has a intake that is at the front of the tractor making it more susceptible to clogging with snow. That's the easiest thing to check, and if it gets much more complicated than that, then the dealer should be looking at it if you only have 10 hours on it.
Sent from my SM-J737V using Tapatalk
fj40dave
Sep 24, 2009
418
255
Yelm, WA
Black smoke: Too much fuel (unburnt in the compression)
White smoke: Burning coolant
No smoke: Motor not running :)
With only 10 hours on the 2650, like the other guys said.....you probably got a blocked intake.
With 10,000 hours, I'd look for a stuck open injector.
Ya gotta tell us what ya find (my money is on the snow [or puddle of water in the air cleaner])
Rcflyer330
Kubota B2650 Cab, B2779 Broom, B2782B Snowblower, RB1672 rear blade
Oct 14, 2019
101
55
Traverse City, Michigan
Like everybody else said you most likely have snow/ice in the airfilter. Once you remove it and dry the filter you should be good to go. Removing the intake tube goining to the air filter will prevent the snow from being sucked in. You just need to remember to put it back once spring comes around. Another option is to use front and side skirts to block the snow from being sucked into the airfilter.
Sent from my SM-N950U using Tapatalk
Oliver
L2501, JD 3520
Feb 2, 2011
526
121
Preston County, WV
Snow blocking the air intake was a problem with some B2650's, naturally that richened the mixture causing the black smoke. I thought I read that Kubota redesigned or modified something on B2650 to reduce the chance of it occurring. There may be a retro fit kit available.
eliot3b4
Kubota B2650
Nov 7, 2019
36
Eliot, Maine
I added some diesel fuel conditioner. The tractor sat in the sunshine and any snow melting off of the machine. Since the additive, no issues what so ever. I did notice some white exhaust yesterday, but no more black exhaust.
I'll check the air intake the next time that happens.
I love this machine. Pure pleasure to operate!
bluefin650
B2650, JD 35D
Feb 28, 2018
Southern Maine
I was having the same issue. I went to my dealer to ask if they had any suggestions. They said they had a service bulletin for the B3350 for the same issue that states to remove the intake tube. The dealer said to do the same for my 2650.
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
394
56
Wa
It's funny or confusing why they state to do this for the 3350 and not the 2650, they are the same.
bird dogger
Vendor Member
Feb 24, 2019
1,575
1,424
North Dakota
Like rcflyer mentioned, if you'd like a set of winter fronts (front and side covers) I'd be happy to help you out. You wouldn't need to mess with the air intake, and in addition you'd gain other benefits as well. Especially in your location. Here's a link to my thread: https://www.orangetractortalks.com/...hlight=kubota+b2650+winter+front+grille+cover
There's also a listing in the "For Sale" section. And I'm with you.....I enjoy my B2650 more, every time it gets used. Our winters can be brutal here, too.
If interested in a set of covers just send me a PM or email.
Regards,
david
Edit: A person here on this OTT site by the name of Vanquisher has an extra grille cover/winter front that he may part with. He's just down the road from you in New York. Here's a link to his thread on that: https://www.orangetractortalks.com/forums/showthread.php?t=44687&highlight=kubota+b3350+bonnet
4,435
I think the post Bluefin650 posted said, "I was having the same issue. I went to my dealer to ask if they had any suggestions. They said they had a service bulletin for the B3350 for the same issue that states to remove the intake tube. The dealer said to do the same for my 2650."
Orange1forme
Dec 1, 2018
394
56
Wa
Right, but in my manual(I think) it states to remove the intake for the 3350 but does not refer to the 2650. :confused:
sheepfarmer
Nov 14, 2014
4,445
662
MidMichigan
Do yourself a favor if you are snowblowing with a B2650 or maybe anything else and buy or invent some kind of front cover. The snow not only gets in the air intake but eventually covers the radiator and other structures with ice even if you take the air intake off. Life is easier if you don't have to clean or melt it off. Before I got one of birddoger' s covers I improvised one with a sheet, and magnets. Made all the difference.
PML3300
Shuniah Ontario Canada
A good way to prevent snow from getting into air filter chamber and choking air is to tape a nylon stocking over air intake location . will let air in and not snow and will not allow snow to melt and saturate paper filter element
busterja21
colorado
frogzskin would be another option at the snorkel opening to keep snow out.use them on snowmobiles to let air in and keep snow out.
Orange1forme
Dec 1, 2018
394
56
Wa
Bought this on Amazon, silicone adapter for a turbo. About $8.00 US.
Used stainless screws, top and bottom.
3,257
I installed one of these and it works like a charm. For $6, you simply can't go wrong. Highly recommended.:D
bird dogger
Vendor Member
Feb 24, 2019
1,575
1,424
North Dakota
Thanks for posting that, dirtydeed! That's what I've been looking for.
Regards,
David
3,257
Regards,
David
Sure thing. I wound up throwing a hose clamp on mine, but they fit pretty tightly. I haven't had to clean the loader arm or bucket since...
Here's a couple of pics of what it looks like installed...
