My tractor is an L4060, meaning a non-turbo V2403 4-cylinder engine. I noticed it does have an EGR cooler, which sits under the exhaust manifold on the left side of the tractor. The cooler has a pipe which goes around the back side of the engine to the right side and into the EGR valve, which controls whether or not the cooled exhaust gases are reintroduced to the intake side. Since I didn't see an electrical harness, I'm assuming the valve is controlled by vacuum.
I noticed the A/C condenser has its own, easy to remove (vertically) screen. The radiator has its own screen as well, but since it slides out horizontally, you cannot remove it without also removing a piece of lower orange-painted trim. That trim does remove without tools, but this does not seem like an ideal design.
I also noticed the air filter is located on top of the engine, midway back, instead of the usual out front of the radiator location. With the A/C components, there isn't room for the filter here. The problem is that without tweaking the hood over to the left a bit, you cannot remove the access door to remove the filter at the end of the canister. It is doable, but harder than other designs I've seen. Sadly, the primary filter is made in China. The finer secondary filter inside is made in Germany. However, I did notice an air filter restriction gauge which is nice, although I believe older Grand L tractors could notify you on the dash electronically (if you didn't notice the blacker exhaust smoke).
Overall, very nice and well made tractor.
