Front end loader B6100
Bountyhunter
32
Alberta
I am toying with the idea of building a loader for my B6100. In my inventory, I have quite a bit of pallet racking. I am debating about using this for the loader arms. It is 1.625x4" tubing. They would be two piece arms. 30" gusset/cyl mount and then 40" 60* down from horizontal. Does the brain trust here think that this would be strong enough????
H
dlsmith
BX2230, LA211
Nov 15, 2018
1,237
794
Goshen, IN
What is the wall thickness of the tubing? That will have a large effect on it's strength.
I would think a 2" X 4" X 1/4" wall would be about a minimum for that application.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
90
58
Lopez Island, WA
The loader that i adapted to my B5100 was (I believe) intended for a B6100. The uprights are about 2 x 4 x 3/16 at most. (tractor is 900 miles away so no measurements, sorry).
Keep in mind that the front axle loading needs to be considered with these tractors; you're is limited to 500 lbs as shown in the owners manual, and a subframe is required.
- Bart
Bountyhunter
32
Alberta
Lil foot. I appreciate that picture as I am just starting to build the subframe. I decided to go with 2x4x1/8 tubing for the loader arms. Pictures coming soon----I hope
H
GillesRoger
B1750 tractor, RC60-B mower, TG2754 Plow, B5320 weight box, B2550 snowblower
Oct 17, 2019
Westphal
Here's a picture of the subframe I made for my B5100.
- Bart
I'm just starting to plan the build for my B1750 FEL and this subframe picture if exactly what I was looking for. Thanks for sharing. Gil from Canada
