M8950 Charging system
tylergrant20112011
Kabota M8950DT
Dec 9, 2018
21
Luverne, AL, US
I have a m8950 and recently the charging system on my tractor is not working. It is running off battery power alone. I've replaced the alternator and still only getting 12v at the battery when running. Is there a inline fuse or perhaps an external regulator on this tractor? Also if someone can give me information on buying a repair manual that would be great.
Thanks
10,255
Have you checked power into the alternator?
You will have to get the WSM from either eBay, or a Kubota dealer.
tylergrant20112011
Kabota M8950DT
Dec 9, 2018
21
Luverne, AL, US
I've checked the power at the battery while running and it was reading 12.4. Also checked the power on the post of the alternator it was reading 12.4 also. The red wire and the 3 wire plug from the alternator goes to the cab.
5,257
1,053
From looking at the wiring upgrade for a B7100 which is of the same era as your tractor I believe you have a voltage regulator.
The three terminals on your alternator with letters E, F & N correspond to three terminals that would be on the regulator.
Do you see anything that looks like this regulator on your tractor? The 3 wire connector would have some connection to it if it exists.
For $14 I would be inclined to buy a new regulator since you already bought a new alternator.
tylergrant20112011
Kabota M8950DT
Dec 9, 2018
21
Luverne, AL, US
Please read my post #5.
The 12 volt signal to start producing power goes to the voltage regulator not the alternator.
After removing the side wall from the dash, I found the problem. The regulator was unplugged. I'm guessing it somehow got stuck to the clutch linkage and whenever the clutch was pressed, it unplugged it. Thanks for the help. There is still one problem though, the battery light is still on, on the instrument panel.
5,257
1,053
What is the battery voltage now with the engine running?
Have you checked all fuses?
3,943
My “M” has it’s regulator inside the alternator.
Several things come to mind: New alternators can be bad. Old alternators can be good.
Did you ever take your alternators to an alternator shop and have them tested?
It’ll do you no good to keep changing parts if they’re both bad, and it’ll do no good to keep buying new replacements for good parts.
A bad terminal, or bad ground can hide all sorts of troubles, so just switching out parts is not a good way to fix things.
5,257
1,053
His regulator is external..... hence the three small terminals
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
The M8950 battery light indicates the electrolyte level in the battery. It usually doesn't work with anything but the original battery because the sensor can't be installed in the replacement battery. The ammeter is the indication if it is charging or not.
