MX5800 being replaced by MX6000?
Garrik
MX6000
Aug 7, 2019
22
San Jose, CA
Anyone else hearing rumors that production of the MX5800 (and maybe other MX tractors) has stopped, because it is being replaced by a new model?
Jchonline
600
Red Feather Lakes, CO
I havent heard anything. I did hear there may be new LX model being announced sometime in the near future...but nothing official.
SDT
Apr 15, 2018
3,674
1,402
I have not.
All such imminent model changes, etc., should be announced tomorrow at the annual dealer's meeting.
SDT
PaulL
B2601, MX5200.
Jul 17, 2017
2,790
1,787
NZ
I think I heard the meeting is this week - first full week in October apparently. I'd guess we'll get a Messicks video pretty quickly.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,190
171
Hardisty, Alberta
There is a MX5400 and MX6000 model coming. The parts and WSM's are available now from Kubota
SDT
Apr 15, 2018
3,674
1,402
Any interesting news from the annual meeting? I don't need a new MX model to enter the back of the mind!
Sorry.
The dealer's meeting is the week of 10/07.
Should know sometime this week.
SDT
troverman
Jun 9, 2015
1,178
266
NH
It's on Kubota's site...you can get a CAB!
Garrik
MX6000
Aug 7, 2019
22
San Jose, CA
Looks, at first glace, like the same machine with slight tweaks. You can get a cab. The 6000 has the same engine as the 5800, but with slightly more horsepower (the machine weighs exactly the same as the 5800).
Does anyone see any major differences other than the cab option?
troverman
Jun 9, 2015
1,178
266
NH
I have a 2018 MX4800, and it looks just like my machine with a cab. I guess even the open station models will get a rubber floor mat now, which is nice. Controls appear to be the same. But a cab option is welcome.
SDT
Apr 15, 2018
3,674
1,402
Saw the new brochure today, as well as the new LX brochure (replacement for B2650 and B3350) today.
Both cabs and gear transmissions are available for MX tractors.
SDT
troverman
Jun 9, 2015
1,178
266
NH
I find it hard to believe it will be that much cheaper. The MX is a larger machine with a stronger loader. I can see it not having HST Plus to save a little money and maybe no dash message display like the Grand L. I’m thinking $4-5k less.
Johnson16
L2501
Jul 9, 2019
10
Metamora, Michigan
It appears you can build your own on the Kubota site now for the new MX series. I built a Mx6000 with cab and loader w/ bucket (MSRP = $44,322) and an L6060 with cab and loader w/ bucket (MSRP = $51,624)..........Just over $7000 less, so perhaps the dealer was not far off.
troverman
Jun 9, 2015
1,178
266
NH
I guess you are right. The MX is a slightly larger tractor than an L6060, and has a slightly more capable loader. The L6060 has a nicer 3-point hitch.
I watched the video of the new cab MX, and its a nice machine. I believe the physical cab itself is exactly the same one found on the Grand L 60 series machines.
I've owned an MX4800 and now an L4060. Here's the interior differences I noticed:
-MX has the old instrument cluster with a digital hour meter but no message center.
-MX has a horn button added to the dash whereas the GL60 has the horn integrated into the steering wheel center pad
-MX has the combination headlight / turn signal / flasher switch on the dash, same as before. GL60 has an automotive-style control stalk off the steering column for these functions
-MX uses the same seat for the cab as previous models, with optional arm rests. GL60 uses a full suspension seat with standard arm rests, 15-degree swivel, reclining backrest, higher back, and glovebox in back of seat.
-MX controls for F/R work lights, HVAC, radio, side mirrors, antenna, wipers, defrost...all identical to GL60.
-MX uses old MX steering wheel; however wheel now tilts.
-MX uses old style controls for 3-point, HST range, etc. GL60 controls are set up higher in the plastic for easier access, and HST range shifter is more like a gear stick.
All in all, some of the GL60's gadgetry is nice and some is unneeded. In my opinion, a cab is a place to be out of the elements and stay cool or warm. The MX accomplishes this exactly as well as the GL60. I really like having a clock in a tractor since I'm in the field a long time. So while the GL does have a clock in the IntelliPanel and the MX does not, most of the radios fitted by the dealer have a clock in the radio (mine does). That takes care of that.
I guess I might miss the HST-Plus transmission. I really like the H-DS flip on the move and the linked treadle pedal.
And I will say that while the new MX cab appears to have the same work lights as the GL60, it also appears to have the old MX's headlights, which are 35W high/low units. The GL60 has 55w/60w low/high headlights same as a car, plus a secondary side light option.
edritchey
2026 Kubota ZD1211L-3-72, 2025 New Holland CNH WM75, Landmaster L5W UTV
Jul 19, 2014
1,186
963
Wellsville, PA
I wonder if the New MX cab would fit on the older style MX tractors
