Glow plug circuit problem L4310
craig68
L4060
Sep 19, 2013
12
MI USA
I have a L4310 and when I turn ignition switch to preheat the glow plugs, the dash light flickers and goes out and a relay chatters. I replaced the glow plug relay and the timer relay and they did not help.:confused:
Any help appreciated.:):):)
BruceP
G5200H
Aug 7, 2016
851
368
Richmond, Vermont, USA
The 'flickering' tells the tale. The circuit is losing its supply-power every time it trys to kick-in and send power to the glowplugs....then repeats over and over and over.
I would check for poor-connections on both the positive and negative portions of the circuit. Also look for wires which are turning to green powder on the inside.
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Dave, give him pages 9-M6 to 9-M9
craig68
L4060
Sep 19, 2013
12
MI USA
My thanks to Bruce and Dave. The problem appears to be wiring.
Found the poor connection.
