I'm sure you guys have seen these before, but I had trouble finding one locally. So a few hours and a junk yard trip later its almost done.
No not really. I dont have much weight on it and There is 8 bolts in it now to help distribute the weight(that was the fab stageFreakingstang the rear receiver looks like it is mounted to your rear axle housing. When you are moving your trailers are you worried about cracking the housing that it is mounted to?????
Freakingstang, Is that a stack I see on the side of your tractor or is that an illusion?Nice fab work... I just have a little garden tractor. I want to fab up a three point hitch for mine eventually. For now I have front and rear hitches that I fabbed up. I use the front for my plow setup off a 5100 for a quick detach setup. The rear gets used for moving trailers and I also made a weight box for plowing that slides in the hitch
Very cool. Simple but effective. Now that is something I think I can attempt to try.Same effect, but at the other end.
I did the same type of mount on a JD 420 WHEN IT BROKE I COULD SEE THE GEARS THOUGH THE FIST SIZED HOLE IN REAR DIFF!!!!!!Freakingstang the rear receiver looks like it is mounted to your rear axle housing. When you are moving your trailers are you worried about cracking the housing that it is mounted to?????
