Moving rear tires - B7100
ajhaig
11
Charlotte, VT
I'm moving the rear tires further out on the axel on my B7100.
Is there anything I need to know?
It looks like the bolt has a spring?
Many thanks.
AJ
hodge
Nov 19, 2010
2,902
450
Love, VA
Nothing major- just make sure that you properly tighten those bolts back down, and make sure that each wheel has a locating pin, and it is in good shape and installed.
hodge
Nov 19, 2010
2,902
450
Love, VA
Many thanks. How tight should the bolts be? Just "tight" or do I need a toque wrench?
Thanks.
Tight. You need to torque them- sorry that I can't remember the amount, but it is up there. They need to be tight, so that the hub doesn't wiggle on the axle.
asbug
B7001 - looks orange to me... Woods 5' scrape, 42" rotary cutter, shreader/chip.
Feb 11, 2011
155
Varnell,GA - USA
Thanks.
Please post a photo of how far out you put yours, I have the Agri tires on mine and i want to move the wheels out further, but I think that I am maxed out now.
Thanks,
KC
hodge
Nov 19, 2010
2,902
450
Love, VA
Thanks,
KC
It's easy to tell- there aren't that many holes in the axle for adjustment- if the tire looks fairly centered with the fender, then you should have one more step to the outside.
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
If you want to get the maximum width posible,you can turn the wheel around on the hubs so the clamp and tube vavle is towards the tractor .you will also have to change the wheels from one side of the tractor to the other so the chevrons face the correct way.I have mine set this was or I would have turned it over long ago:eek:
dave
meanjean
Kubota MX4700
Aug 10, 2010
922
Hazelridge, Manitoba
I finally spent the $35 on a torque wrench, should have a long time ago.
Car tires are torqued somewhere around 90 foot pounds.
Tractor would probably be a bit higher but I tighten mine to 90 lbs as well.
