D1105 Oil Pump Cover Screw Torque
ButchB
B2530HDB LA435 QH15
May 19, 2019
32
Phoenix, Az
I am inspecting the oil pump on a D1105. The WSM does not list a specific torque for the pump cover screws, yet the inspection procedure entails checking the cover clearance with plasti-gauge, (1-3 thousands), so it may be important.
Does anyone have any input if the torque is other than standard?
Thanks
8,731
Thanks
The clearance in this case does not have anything to do with cover torque, it has to do with component wear.
So a standard torque per bolt size is normal.
ButchB
B2530HDB LA435 QH15
May 19, 2019
32
Phoenix, Az
Thanks for the reply.
The attached pdf shows the inspection. I will use the standard torques.
