This will be a long post, I apologize for the length but hope that you will bear with me and afford us some of your expertise. Thanks in advance.
My wife and I are going to / have been pricing a tractor before the finance cut-off at the end of the month and see if the math works out for us or not.
(Now we know the math works, but not which tractor is best for us.)
We are currently on 2 acres. We would likely be on 50-100 acres north of here within 5 yrs, depending on market.
We would not be working that amount of land. We enjoy nature and solitude, we like hiking and seeing wildlife. We would have enough yard to keep the bugs down around the house, but nothing elaborate. We are pretty low-key outdoors kind of people.
We would be getting the tractor now instead of later to:
*give it the proper break in before we need to pound the hours on
*both learn to use it with confidence before we need to be able to perform under pressure of time constraint while building our next house
*know that the maintenance has been done at or better than spec, and know that we will get the full life of the unit. At least we would know what happened and why, and have 6 years to get it ironed out on warranty or KTAC
*replace the snowblower that i can't push through or down into the snow drifts here. I think the trees across the road act like a snow fence, depositing the snow in my driveway and the wind from the lake packs it hard.
*finish the landscaping here, construct our food garden, top-dress the holes in the lawn, construct the flower type gardens, rebuild the swale that has flowed into the ditch, etc
*help my father in law with getting firewood
*spread some dirt at my parent's place so dad can fix his lawn
*take advantage of 0% for 6yrs with 6 yr powertrain, this also allows us to take advantage of KTAC which is apparently only available in Canada on new, financed Kubota's.
What we would use it for in the future:
*Rough entrance/ driveway
*test hole for septic permit
*help with clearing property
*covering o-pipe around foundation with gravel
*back-filling (if I have to wait for excavator, has cost me a week or so in the past)
*rough grade(if I have to wait for excavator)
*moving lumber
*moving brick
*moving rocks
*lifting beams
*lifting plywood to roof (not full 60sht lifts)
*window install, moving windows around
*moving skids of hardwood and tile
*gravel for under decks
*if we get bh subframe and rent / borrow bh: hydro trench, drain trench, evestrough drains, possibly sonotubes, propane line, well line
propane tank install
*fix rough grade and spread top soil
*fine tune finish grade
*power rake / harley rake for preparing final grade or similar attachment
*possibly post holes for fences
Ongoing from completion of next (hopefully last) house:
*help getting firewood (grapple would be so sweet)
*snowblowing
*rototilling or disc-ing garden
*keeping access trails open, some bush hogging
*regrading heaved driveway ( I notice everyone I know with property up north always needs to re-do their driveway spring and fall)
*mow with it then, wether mmm or 3pt,
I have been doing the research for us on this, but we both have been out test driving etc. My wife says the B seems like a better buy based on my research, but that she would get used to either.
What I like about both tractors:
*large engine de-tuned to make it's power at low rpms and below the DPF line for HP.
*ground clearance
*good fit for lifting capacities and implement sizes for our uses
What I like about L2501
Bigger wider frame.
Thicker axle shorter axle length, seems like it has to be stronger.
Bigger HST, cast iron housing, looks strong as heck.
Old school dash, no digital nonsense.
What I don't like about the L2501
Conventional power steering. I work in the housing industry, I work around excavators and heavy equipment a lot. 99% seems to have hydraulic steering. A friend of mine owns an excavating co. and has told me he would not own a piece of equipment with conventional PS and a loader. I know on my truck working it all the time that steering components are wear items really, especially the pitman arm. Seems like Kubota really went backwards here.
Weaker hydraulics. Lower lift capacities front and rear compared to the B. Also the third function apparently can only be a line to the front and then the valve is on the implement. Since most equipment has the valve on the unit, this makes renting or borrowing attachments difficult.
Can't get more than telescoping stabilizers on 3 pt.
What I like about the B2650:
Hydraulic power steering.
Strong hydraulic system, can have third function, rear remotes and better lift capacity.
fully adjustable 3pt hitch available, telescoping stabilizers / link ends and ratcheting lift rod.
the seat.
What I don't like about the B2650:
Digital dash
I wish the HST/axle/frame were as beefy as the L. I know that similar sized units have been working longer than I've been alive, but I like solid frame a lot.
Aluminum housing on rear. Seems fragile compared to L, anyone ever have trouble??
Concerns that the tractor won't last longer than me. We are generally people who buy equipment once and maintain it.
In general, we often find that buying the best of class is usually the correct choice. The B2650 is going to have all the top-tier components of the series, whereas the L2501 is going to have some compromises like conventional PS.
We are not able to purchase a top of the line L-series. That said, maybe in this case the benefits of a larger frame outweigh the downsides?
What we want:
*HST
*4WD
*ROPS
*Alternator, would have to upgrade the B
*Ideally loaded turf tires with enough plies that they have the puncture resistance of R4's Do they exist?
*wheel spacer kit
*Block heater (just in case)
*Front loader, SSQA
*third function valve
*60" bucket
*QA pallet forks
*hydraulic spill guard
*Backhoe mount kit and plumbing so I can borrow my friends BH77
*2 rear remotes. One for snowblower rotation etc, one with float (I think?)
*64" 2-stage snowblower with hydraulic rotation
*Telescopic lower links and stabilizers, ratcheting lift rod.
Anything on my list that just can't be done with either, I would look at suggested options or arguments for or against as well.
Would you help us make the best decision for our purposes?
Now I am going to the garage because if I don't clear it out and build some shelves, there will be no room for tractors
*moving lumber
*moving brick
*moving rocks
*lifting beams
*snowblowing
*ground clearance
Bigger wider frame.
the seat.
Digital dash
What we want:
*HST
*4WD
*ROPS
*wheel spacer kit
*Front loader, SSQA
*60" bucket
*QA pallet forks
