Hello all,
I am very new to tractors and have very little knowledge about them. About a month ago I bought a 1975 L225 2wd Kubota. The hour meter on the tractor said 300 hours but the previous owner said the cable had been broken for a time and the tractor actually had a little over 1000 hours use. I have been bush hogging a hill with some small trees and doing some light driveway work with a 4' grader. The tractor seems to have plenty of power and works well. I got off of the tractor yesterday to move a limb and noticed the crankcase vent was blowing a little smoke. The smoke seemed to be consistent. Today I noticed there was a couple of drops of oil in the garage under the vent. I'm sure its blow-by. Is this something that needs immediate attention. Otherwise the tractor is in great shape. It is not very noticeable but I don't want it to cause any further damage. Is this something I should let go until I notice some significant oil usage or should I be more proactive and fix it now? Does this usually remain stable for a long time or, if left untreated, compound problems later. I would like this tractor to last. I will probably use the tractor less than 75 hours a year. Lastly, are the parts to overhaul this engine still available and from where. Thanks.
