BX 23S vs. 2380
EstonP
BX2380, SSQA Loader, Grapple, Land Pride Brush Cutter, Box Scraper, MMM
Apr 11, 2019
Ringgold, GA. USA
Besides a slight difference in HP, what is different between the 23S and 2380?
7,349
I believe they are pretty much the same tractor, except for rear end construction to attach a backhoe to.
The 23s is obviously designed to accommodate a backhoe, whereas the rear end of a 2380 will not accept one, either Kubota or aftermarket.
I have a BX2360... couple generations earlier, and that was the story then with that versus BX24 or BX25/25D, which were designed as tractor/loader/backhoes (TLB).
I don't believe it has changed.
Sent from my QTASUN1 using Tapatalk
EstonP
Apr 11, 2019
Ringgold, GA. USA
Makes perfect sense. Thanks for the response.
PaulL
B2601, MX5200.
Jul 17, 2017
2,801
1,792
NZ
Usual list of differences:
1. Wider ROPs, to make room for the turn around seat
2. Turn around seat so you can use the backhoe (much better than a 3ph backhoe without turnaround seat - as the backhoe sits much closer to the machine, so better departure angle when loading onto a trailer)
3. Subframe that the backhoe attaches to. The BX frame isn't super strong, they decided that it needed reinforcing for a backhoe. The BX23s has that reinforcing, I believe it reaches most of the way along the chassis
4. No 3PH equipment. The hydraulics are there, the arms and top link aren't, you can option them
5. I think the loader is slightly different, but not enough different to care I believe
I think they're actually identical horsepower, they're in the middle of rerating their machines so the horsepower they used to claim is no longer the horsepower they claim. You may have two different sources of info, one before the HP change and one after. I'm pretty sure it's an identical engine.
leveraddict
Apr 1, 2019
905
594
NEPA
Yes the 3 point arms are on a BX23S. Drop the backhoe throw on the 3 point and your ready to go!
LukyNumbrKevin
2018 BX23s (TLB w/ a mower deck)
May 17, 2018
42
CT, USA
The biggest reason I went with the 23s over the 2380 was that with the 2380 there is no way to put a back-hoe on it in the future. The sub-frame that comes with the BX23s for the back-hoe is built into chasis so there is no way to retrofit it to a 2380 with out a very expensive labor bill.
If you are curious to see the BX23s in action check out my YouTube channel through the link in my signature below.
LukyNumbrKevin
May 17, 2018
42
CT, USA
I think he means that the 3 point hitch connector arms to connect your implements to the tractors 3-point hitch. The BX23s does very much have a rear PTO and 3-point function, you just need to buy the arms which I think set me back about $160, but I just included them in the financing when I bought the tractor.
PaulL
B2601, MX5200.
Jul 17, 2017
2,801
1,792
NZ
Correct, the lift arms are there (the hydraulic bit), the lower arms, turnbuckles and top link are not. They aren't overly expensive, but it's a cost to factor in. I'd also recommend looking for telescoping stabilisers instead of turnbuckles, the turnbuckles generally suck.
leveraddict
Apr 1, 2019
905
594
NEPA
Apologies Paul. Still learning all the new tractor lingo!
GRBates
Kubota BX23
Mar 14, 2025
For the record, I just finished converting a BX2380 to a backhoe/loader. I had a wrecked BX23s from which I unbolted the loader brackets (2 pcs), backhoe side frames (2 pcs), and rear backhoe brackets (2 pcs, these are called fender stays in the parts manual). Also had to move a hydraulic return line from the 23s to the 2380. I didn't have a swivel seat, so I made a drop-in seat that works fine when I use the backhoe. everything bolted on and no welding was required. Backhoe and loader function properly and the quick attach in great. The 2680 already had the joystick and hydraulic fittings for the loader
