B26 manual thumb
Birmingham
B26
Mar 27, 2019
Birmingham AL
I know there must be a manual thumb kit from kubota but i have spoken with 2 dealers one being (messick) who say the only thing that fits the b26 with the BT820 hoe is the powered thumb and that kit is 2000$ for parts only.
something similar to this,
I cant post the link because of a post count its a manual thumb at bxpanded
I know its not listed as fitting. The hoe comes with the eye welded on for the top already.
Thank you for your help, I have spent hours trying to find this.
nbryan
Jan 3, 2019
1,320
841
Hadashville, Manitoba, Canada
This is the thumb on my BH77 hoe, looks like what you need? I could send measurements if helpful. IMG_20190327_123238437.jpg
Sent from my Moto G (5) Plus using Tapatalk
Jchonline
599
Red Feather Lakes, CO
I dont see one listed on Kubota website either. Just the hydraulic. I think you are going to have to get one fabricated, or find another model that can be modified to fit.
nbryan
Jan 3, 2019
1,320
841
This is the thumb on my BH77 hoe, looks like what you need? I could send measurements if helpful. View attachment 41795
23 3/4" between end of dipperstick and thumb mount flanges pins. 2 9/16" gap for thumb bar at mount flanges with 1" pin.
shootem604
Apr 23, 2018
874
British Columbia
Take some pictures of what you would like and of your setup with measurements to your local fabrication shop - they should be able to make up a manual thumb pretty easily. I bought the bolt on thumb for mine from amazon, and it's been very useful already.
Birmingham
B26
Mar 27, 2019
Birmingham AL
Your thumb is exactly what i have in mind, the distance between the boom ear and the main pin on the bucket i dont really care about i can cut or weld on an extension the adjustable part.
what will make or break that is:
1. the pin diameter in the ear on the secondary boom, the length of that pin when installed? I can make spacers or again cut it down.
2.the diameter of the main bucket pin as well as the distance between the ears that go outside of the existing bucket mount?
3. how long is the tooth part I dont know what else to call this the part that goes from the mount pin to the teeth on the bucket.
thank you very much in advance.
nbryan
Jan 3, 2019
1,320
841
6" long x 1" diam. pin for dipperstick thumb mount flanges, main bucket pivot 10" x 1" pin, actual thumb as per photo. IMG_20190327_185758653.jpg IMG_20190327_185850415.jpg IMG_20190327_190001504.jpg IMG_20190327_190941710.jpg
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
544
520
Lake Almanor, Ca
B76A here with thumb. I soon found that a manual thumb is a total pain in the ass...I plumbed the rear remotes and the ram...for about 8-900$, the ram was about 400 and the thumb was 600 I think. The hydraulic thumb is the most valuable asset of my tractor...use it almost every time I use the tractor...money well spent.
nbryan
Jan 3, 2019
1,320
841
The inside faces of the thumb pivot mount at the bucket main pin are 6" apart - in answer to the other question about outside of bucket mounts. All my measurements are close but not precise, using a carpenter tape, and BH is still in storage so can't reposition.
Jchonline
599
I am of course with Armstrong. Many, many folks told me to get the hydraulic thumb. It has certainly been worth the money.
Birmingham
B26
Mar 27, 2019
Birmingham AL
Thank you so much, Ill post up the B26 numbers tomorrow, so that anyone who looks this up in the future can see it, The Hydraulic thumb is 2k parts only. Im 100% sure i can install it but have heard its a real pain in the... The tractor can run a hammer also if I add that kit, this would be nice esp since i have some concrete that needs to go. If i cant get that to bolt on I still may go with the hydro kit. Ill post measurements either way.
Jchonline
599
Sorry to hear it didnt work out. It will burn the pocketbook, but you will be happier with the hydraulic thumb :)
Hake
Ky
This is where the good times come to an end, the bucket design seems to be totally different... Its a decent amount bigger mounts on the B26.
I'm looking for a mechanical thumb on my B26. What did you end up getting or doing?
