Kubota M series, one year old, has new fuel filter and water sep filter just changed. Curious what do others run for fuel or do they just park it until spring? It's only -10F. Thoughts are the fuel is jelling. Thanks David
What model M tractor. They are working just fine up here in Alberta at 30 below and lower!Kubota M series, one year old, has new fuel filter and water sep filter just changed. Curious what do others run for fuel or do they just park it until spring? It's only -10F. Thoughts are the fuel is jelling. Thanks David
The fuel suppliers here adjust the blend for the season so if you are running fuel in the winter that you bought last July you WILL have gelling problems. Kubota ( And all other manufacturers) Recommend against any fuel additives In engines with a DPF and urea emission control system.Kubota Model # M6/141
could be the fuel Im getting at Co-0p
What do you run for fuel?
I doubt our fuel here come from anywhere near the same source as yours does.Are you running a bio-diesel and what brand? I will call the co-op fuel manager. We might be the only Kubota buying from this Co-op and therefore no one else has reported problems.
Eserv, is the key word in that statement dpf AND urea emission control???? I had not heard that for my L3560 with only a dpf filter, and the manual suggests adding cetane boosting additives if needed. Also my dealer handed me a bottle of a Kubota fuel treatment that has anti gel properties, which I have been using. I wondered about its effect on the dpf filter, and because of the design of the fuel tanks (divided) it is hard to get even mixing if you put a whole dose in all at once. I believe the exhaust smells different when first added, so I can imagine it might affect the dpf.The fuel suppliers here adjust the blend for the season so if you are running fuel in the winter that you bought last July you WILL have gelling problems. Kubota ( And all other manufacturers) Recommend against any fuel additives In engines with a DPF and urea emission control system.
Kubota Engines are designed to run on low sulphur diesel fuel and shouldn't need any additives in North America. Anything you add to the fuel will have to pass through the DPF and likely contribute to earlier than optimal need for mechanical cleaning. You do gotta do what you gotta do though if you run into gelling or other problems! I certainly recommend that you add nothing to the fuel unless you are trying to fix something. It is the DPF that is sensitive, the Urea part just injects into the exhaust to reduce NOx . It in itself doesn't care what is in the fuel.Eserv, is the key word in that statement dpf AND urea emission control???? I had not heard that for my L3560 with only a dpf filter, and the manual suggests adding cetane boosting additives if needed. Also my dealer handed me a bottle of a Kubota fuel treatment that has anti gel properties, which I have been using. I wondered about its effect on the dpf filter, and because of the design of the fuel tanks (divided) it is hard to get even mixing if you put a whole dose in all at once. I believe the exhaust smells different when first added, so I can imagine it might affect the dpf.
Well..... believe what you will, but the whole purpose of Tier group Emission standards is so your and my great-great-grandchildren will have a nice place to live. Your descendants will likely be farming with electric tractors anyway.I realize this post may not be helpful in this thread.... but when I read these topics that involve Tier/Emission issues.... it gladdens my heart that I found/bought a low-time pre-Tier/Emission tractor.
I hope my great-great-grandsons still operate it when I'm not even known by them.
