traumadoc2b
B2650 LA534 BH77 bucket forks snow blade box blade flail grapple harrow rake
I've been working on a set of rear remotes for my B2650 ever since I bought a flail mower with 2 sets of hydraulics on it. Unfortunately I've put this project on the back burner given the winter weather, but hope to complete it in early spring.
This is sort of where I decided to put everything once the parts showed up. The valve body is in a plastic bag because it was pretty much coated in oil.
I bought 2 sets of Pioneer Lever Actuated Quick Couplers with mounting brackets.
http://ph.parker.com/us/en/pioneer-...hydraulic-up-to-3000-psi-iso-5675-9500-series
The rear remote valve is a Prince Wolverine mono-block 8 GPM with 2 spring center spools - one has a float detent. It has inlet, tank (pressure-relief) and power beyond ports.
http://www.princehyd.com/Products/Hydraulic-Valves/Mono-Block
