rear remotes on Grand L6060HSTC
Dennis.D
L6060, Erskine hydraulic snow blower, back hoe
Feb 16, 2018
148
59
Central, ME,USA
Does any one have a picture of the rear remotes on a grand L6060 cab tractor? I am looking to add 2 remotes for top and tilt. Its about $2200 at dealer. I do a lot of mechanic work, but have no experience with hydraulics. If its a kit with instructions I'm sure I can put it all together. Looks like its very tight working in that area (I have the back hoe attachment) so I assume 1/2 the estimate is labor.
Thanks for any help there is not much information on internet or anywhere else I have looked for this model tractor.
SDT
Apr 15, 2018
3,706
1,425
I have three remotes on my GL6060 ROPS. Sorry, no photos.
Kubota kits do include installation instructions. Installation is straightforward but time consuming.
Cab is more time consuming and BH more time consuming yet.
SDT
SidecarFlip
Banned
563
Had a 5030 HSTC cab years ago and it is tight but doable.
jajiu
Jun 5, 2016
456
Rowley, Massachusetts
I have a 3560 that I had 2 extra remotes installed with the one I had and the dealer told me that 3 was my max. Here is what it looks like.
Dennis.D
Feb 16, 2018
148
59
Central, ME,USA
jajiu,
Do you have enough room for the top and tilt cylinders with a the back hoe brackets?
jajiu
Jun 5, 2016
456
I only have the top link, but I'm sure there is room for the tilt. I got mine from Fit Right Hydraulics, check with him I'm sure he has done one or two in his time.
tstae
Lynnville, Iowa
I added two remotes to my Grand L 4760 with cab. Just need to remove the back wheel and that will get you access. The instructions that came with the kits were very good.
I got my kits from Messicks.
MtnViewRanch
917
382
Lakeside Ca.
My understanding is that the Kubota T&T set will not work with the back hoe sub frame. The way that I build the Fit Rite units, there are no clearance issues and yes I have provided several T&T sets for L6060s with back hoes. ;)
racerboy
L6060 Cab, 1055 loader, grapple, BH92; RTV-Cab
May 10, 2021
247
226
NJ
I realize this is an old thread, but I believe I need to add two more rear remotes to my L6060 cab. Right now, I only have one, but I am interested in picking up a Del Morino Super Centurion flail mower that has both a horizontal cylinder as well as a vertical one, plus I have a hydraulic top link on order. So I think I now need three remotes. Dealer told me the rear remotes were $1250 each plus labor for installation. Does this sound reasonable?
7,361
More like $800 each
JonM
Nov 29, 2024
292
696
wisconsin
i have a bh92 backhoe and a kubota top tilt kit. yes it does rub if you do a full tilt so limit that tilt and it works fine. i havent found a reason to do a full to the stop tilt on any implement.
WMK
L6060, BH92, SGC1060
Apr 8, 2025
9
Ontario
Do you have the Kubota part number on hand? In the same boat and wanting to ensure I ask the dealer for the right kit. Thanks
JonM
Nov 29, 2024
292
696
wisconsin
sorry i dont i had the dealer install mine it took them two days they had to take the cab apart and remove the right rear wheel
