I have looked at lots of other posts on this topic and still can not fix the problem. This has been this way since the first day and I bought it new.
My loader is low by 1 1/4" on the right side. I have checked tire pressure and made it the same if the pressure is the same the loader is off more. I have 21lbs in the right rear and 15lbs in the left rear tire. That gets it as close to level as I can. I have taken a level and placed it on the highest part of the tire and messured from level ground up the tires are the same size. I have removed the loader and checked th distance from ground to top of the notch the loader sits in it is 1/8" lower on left side. Also put level on loader mounts they are out of level both leaning to the right of the tractor from the driver's seat. Please help I can't grade or use forks effectively because of this. Took to dealer they said it's ok
