Stomper
2017 L2501. Landpride Mower. Farm King Snow Blower. DIY Root Bucket grapple.
I was wondering what that strap was doing thereThe nylon strap used as a winch brake is too funny!
Maybe a quick video also if it's not too much bother.Thanks for the encouragement guys! I've got a few smaller trees and some bucks on the hill next to my construction site (building a house). As soon as I can catch up from all this rain we've been having I'll hook it up and give it another go.
My Dad did turn a new captan for me, this one is 8" tall so that I can get a lot more loops on it. I'll see if that helps and try some other pieces of rope too.
Thats interestingI have never seen one of those before so I'm not sure exactly how it functions, but I think you would have to pull really hard to get enough friction to pull a log.I was trying to post when the laptop calved.
I was thinking of something like a pot hauler that they use on boats.
It is like a "V" pulley instead of a capstan and there is a "knife" to stop the rope getting caught in the groove. To disengage the pulling action you simply pull sharply on the slack end of the rope to get it out of the groove.
No. If the rope is sized properly for the pulley they have a very good grip. You are basically just coiling the rope. If you look at "Deadliest Catch" that is what they are using to haul the pots, except bigger.Thats interestingI have never seen one of those before so I'm not sure exactly how it functions, but I think you would have to pull really hard to get enough friction to pull a log.
Yes he did. He's my treasure!Your Dad did a great job with turning the capstan. The extra wraps that new capstan will allow should definately help with the rope slippage issue.
I just noticed that early versions also had my fairlead mounted too high. That was fixed later on but won't appear in the video I post.First I tried flipping the capstan over to reverse the bunching but that didn't really help. I also tried using the little nudging wedge that comes with it and all that did (mostly due to poor mounting on my part... I am not (yet) a welder) was score my capstan and pinch my rope in half.
Does Lewis winch have a capstan winch? All I could find on their site was cable winch run by a chainsaw.Throwing some ideas out there about rope slip... Too many wraps on the Capstan ir how about applying a knurl to the inner diameter of the Capstan. That would really give you bite.
I own a Lewis winch btw, I use it on my property up north for skidding logs but mine is driven with a chainsaw powerhead and I tie it to a tree. With the Lewis, all you need is 2 wraps.
My tractor hydraulic system puts out 5 gpm at 2200 psi. I have researched and found a hydraulic motor for a capstan winch that will give me close to the 60 rpm I am wanting at 5 gpm flow. My question is, at what engine rpm are tractor hydraulics rated. In other words, I want the motor to run at 60 rpm when the tractor engine is at or just above idle not at or near max rpm. How do I figure this into the selection of the motor.
The motor that I found is 15.4 cu.in. motor. How do I know if this motor is sized right or if I need a smaller or bigger flow motor to get the rpm I want at or near idle.
Thats awesome. Thanks for the link to the calculator, it helps out big time for my selection. Now I can run the performance data of the motors I have been looking at and find out which one would work best.If the link works, here’s some calculators.
I’m afraid I haven’t found the flow rate at idle output yet. Or how to figure it based on the rated flow at a certain rpm that we are given.
Another important consideration would be the amount of torque produced by the hydraulic motor at idle or low rpms to drive the winch.
The hydraulic motor could turn at the required speed but have no strength when loaded.
Torque is the reason for the “grunt” of an engine as it labors at lower rpms fixed by revving the engine up slightly.
https://www.womackmachine.com/engin...nd-calculations/hydraulic-motor-calculations/
