Those Darn Doors, Part 1
Just like the window frames, the door frames were built using the cab frame as a template. Hinges spacing their reveal and 1/4" stock spacing the remaining 3 sides. Unlike the windows however, these required them to be built in 2 steps, 1 for each plane. The lower frame section was built first and, the upper section last. By doing it this way, the only compound miter I had to deal with was the front upper post where it intersects with the horizontal member. Everything tacked in place, the 142 clamps removed holding spacers, etc in place and welded up on the bench. I don't have a full blown shop like some of you, only a few hand tools. My welding bench is a piece of cement board layed over a pair of sawhorses. Been working so for, so why switch!
So far, so good. They appear to follow the cab opening and every thing should be good, just need to get the hinges installed. I chose a location for the lower, transferred hole locations and went to drilling and tapping those. Now for the uppers. Because I chose to not build a big box (thanks, Chim) and didn't want to fight the weight of the door trying to open them, I have them swing plumb. The upper hinge pin needs to be out in space, so to speak. This was a bit of a challenge at first and required a couple of head scratching and multi-grain, fat free, protein enriched energy drinks to figure out. Just as I dutchman'd in 1/4" stock for the other hinge locations, I did the same for the upper hinge location on the doors. Only instead of 1/4x1, I used 1/4x3 and left the length long, the excess protruding towards the outside of the cab. Again, the door frames were set into the opening on 1/4" spacers, lower hinge installed and using a length of all thread, I was able to locate the upper hinge positions. Transfer the hole locations, drill and tap a few more holes, cut off the excess 1/4x3, install the stops in corners and we should be good to go!
WRONG!!!
The right hand door fit like a glove. My angle followed the cab almost perfectly. I couldn't ask for anything better. Remember the bling hog finding an acorn??? It applies here! Well, i'm all proud of myself and move to the left hand door, the one I'll likely use the most. Well lets just say i'm less than pleased on how this side turned out. The hinge side lines up well with the cab frame but the front doesn't. I'm off a least a degree or so. I know it doesn't sound like much but, over 30" it adds up pretty quick. My door reveal when viewed from the front started at my planned 1/8" at the intersection of upper to lower but, by the time I got to the top of the door it was like 3/8-1/2", totally unacceptable.
Out come the cut off wheel for my angle grinder and the propane language as I proceed to correct this mess I have created. It took 3 or 4 attempts to finally get this side to a point I thought I could live with. Thank goodness that's done! This had to be the most aggravating part of this build. And, this is the reason I wasn't about to attempt to build flush inset doors in the first place!
Up next: Those Darned Doors, Part 2
Hope you enjoy
WRONG!!!
Hope you enjoy
