Post auger ?
tater pop
64
Maud texas usa
I have a mx5100 and my post auger is just to long. My tractor will not raise it but about 1 inch above ground,it's like a sore thumb to me.Can I shorten that auger in any kind of way?
mickeyd
Mar 21, 2014
1,192
Guin, AL
Which auger do you have?
Most post hole diggers have more than one hole for the Angle Adjustment. Make sure to use the hole closest to the tractor for the most height.
SidecarFlip
Banned
563
I actually lengthened mine. Mine was too short to get a full 4 foot hole so I welded on a suitable length of schedule 60 pipe. You can shorten it. Just saw it off and redrill the hole for the shearpin.
10,480
where the center beam Or top link of the post hole digger attaches to the tractor there multiple holes.
The lower the attachment the higher it will lift (red arrow low lift Blue arrow higher lift.
tater pop
64
Maud texas usa
My top link is in the bottom hole, but I will check out all options before I chop saw the shaft of the auger. I like how long it is but I don't like how it catches on every high spot when I'm moving. I do keep a chain around the auger and main frame to keep it tilted but that's not enough,it still catches on high spots.
10,480
It could also be that the three point is set to not go any higher via the control or the feedback linkage. ;)
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,280
180
Coyote Flats,Texas
with nothing attached to fully raised 3pt see if you can raise draft arms higher. If draft arms can be raised up by hand feedback rod isn't adjusted correctly.
7,285
Are there multiple holes in the lower links to attach the lift arms?
Seems some have two or three(?). Not familiar with MX at all.
If the links are attached to the one farthest out, lower links will lift more weight, but not as high as a hole closer to the tractor.
7,285
I looked up MX5100 on:
https://apps.kubotausa.com/illustrated-parts/
Agree to the legal, type in your model #.
I found the diagram. Looks like you have two points. I'd move it back toward the tractor, if not already there.
Unfortunately, I'm not smart enough to attach the diagram....
tater pop
64
Maud texas usa
Thanks I'll try that and if it isn't that way my plan B is to weld a three inch 2 3/8s pipe spacer to a 4 inch angle iron and lower the hitch pins about 4 inches.
maclean
BX25D
Jun 25, 2014
242
Lowell, Or
My Everything Attachments grapple on my little BX25D hooks up with inside pins to give me more range of motion... something else to consider.
tater pop
64
Maud texas usa
I did it today,I welded two 2 7/8 pipe spacers on the angle brackets on the auger and another 4 x 4 x 3/8 angle iron on to the spacers and added two holes for my 3 point pins now I can raise the auger about five inches higher. hope it works
