Greetings all:
First post. I am preparing to sell my late father's L295DT on behalf of my mother and I am trying to get a feel for its resale value. I understand that the tractor's value might vary geographically. Tractor is located in suburban Houston area. My plan is to bundle the tractor and its implements and allowing the prospective buyer to negotiate what implements they want and then sell off the remaining implements separately. I'm presuming that I will list it on Craigslist - other suggestions? I intend to attach each implement and take a video of its function and have a link to the video in the Craigslist add.
L295DT, 1692 hrs, my father bought it around '83 (as a dealer repo). Grille is missing, engine cover is loose. Paint faded but not rusty. Not sure how to properly shut off the engine - I used the compression release - might have a shut off issue. My mother mentioned that the tractor had a hydraulic leak and the case needed to be split to repair. No idea if this service ever happened but there was no noticeable oil stain under the tractor.
Kubota loader
Kubota backhoe, Backhoe has a hydraulic leak, backhoe has been idle for about 8 to 10 years and the slab the backhoe is sitting on has a 6 ft dia oil stain.
Brush Hog brand post hole digger w/ 6 and 12 inch dia augers
6 ft rear blade
IMCO rear scoop (don't think it has much value, left over implement from the prior 8N)
14 ft double axle trailer (w/ mobile home axles)
Kubota loader
6 ft rear blade
