I’m located in middle TN and recently purchased 20 acres and half of it is grown up in buck bushes and bodocks. Can anyone recommend a grapple to rip out the buck bushes and help pile brush to burn that will fit my tractor?
No, I don’t have the third function yet. I’m trying to decide rather I want third function or to run hoses to my rear remotes. I think I’ll like third better with a grapple but I’ve read it will not work with a skid steer auger setup.Do you already have 3rd function on the FEL?
I went with the LandPride SGC1572. Expensive but got it with my tractor. It is awesome. The rake style allows you to double it as a landscape rake in lots of situations, so you can rake up brush and debris easily. I see lots with the longer straight tine grapples as well.
I seriously looked at that bucket retrofit style grapple. But for clearing brush, being able to sink the lines into the roots and curl up to pull the roots up makes big a difference in clearing out brush (and even small trees), or even sink the tines into the roots and push forward to pull up brush - roots and all.This is bolt on grapple I installed on my 4600.
That's what I really like about it, I can drag branches and other things as well as level out areas with the jaws wide open and then clamp everything and move it to where I want to put it. I do have a 3rd function and love that too, easy to use, right on the joy stick.How do you like the rake style?
Buy a HD 6 foot L style one and I will trade you my rake style for it.How do you like the rake style?
If you go rear remotes, make sure you have a switch on the loader control arm to actuate it. You dont want to use the normal rear remote control. I have seen people use those and it is very frustrating if both are on the right side.No, I don’t have the third function yet. I’m trying to decide rather I want third function or to run hoses to my rear remotes. I think I’ll like third better with a grapple but I’ve read it will not work with a skid steer auger setup.
I have looked (on line) at the SGC1572. How does it do with ripping roots out of the ground? Do you feel limited on how much you can grab at a time with the short times? Do you mind telling me what you have for it? My dealer is closed for the rest of the week.
Mike out of curiosity, what dont you like about the rake style?Buy a HD 6 foot L style one and I will trade you my rake style for it.
I ordered a 72” Quick Claw tonight. It should be here in 2 weeks. Merry Christmas to me.I have a L3560HSTC and I got a good strong Quick Claw Grapple from QuickAttach.com. Made in MN, good American made quality.
I don't think you'll regret it. I'm very happy with mine. The long hoses are a minor problem, I use a bungee cord to try to contain them, works ok. I also use it to pick boulders, but be careful, as all things can bend with too much pressure. I bent one and had to heat and bend it back into position. Good luck with it!I ordered a 72” Quick Claw tonight. It should be here in 2 weeks. Merry Christmas to me.
I bought some on ebay. I got oversize to slip over the connectors and used zip-ties to hold it on the ends.Sounds like good advice. Do you know where I can order the black sheath that comes on factory hoses?
