L3350 Field Find
CobraTom
L5030, L3430, L4310, L3410, B3030 , R510 currently..
Sep 19, 2011
126
Ontario
How do you know that?
Because you can see it in the parts diagram that I pulled up. Single shaft leading to clutch.
Dual clutch requires a inner and a outer shaft, no such thing on any of the Hydraulic Shuttle diagram.
The purpose of a dual clutch is to not slow down the PTO while shifting gears. Mechanical Shuttle or GST requires clutch in. Hydraulic shuttle does not require clutch in for this as it has its own set of clutches.
6,363
GST's do not require a clutch in either, as it too has it's own clutch pack.
