Im confused. Im in need of a new battery for my L3400DT. Ive read that a BCI Group 24 will work but the length on this group seems to be slightly to long. I carefully measured the distance between the brackets that hold the bottom of the battery in place ( "L" shaped metal tabs) at 10 1/8" (257mm). The BCI length dimensions for a group 24 battery are listed at 260 mm (10 1/4"). Thats dang close. Cant find the BCI definition of length. Are the BCI dimensions maximum overall values or what. If this is the case (another pun) then it is entirely possible that the minimum case dimension length may be short enough to fit between the battery base containment brackets. To try to state a little differently, the battery cases overall maximum length could be slightly more than its minimum case length. I fact I think this is the most likely scenario but I hate to order a battery only to find that its an 1/8" to long.
Wadayathink? Anybody put a BCI Group 24 (260mm case length) in a Kubota L3400DT? I live near a small town. Not a lot of places to look but guess i will go to Walmart and measure one of their group 24s and maybe hit one or two auto part stores to see what they have. Not sure I trust calling battery vendor. Trust my own measurements more than some customer service rep.
