I'm thinking a 6 footer might be a little too much, but it might do it.Yes B7800, sorry.
I'm thinking its a bit much too - BUT you do have 30 HP to do it with.I'm thinking a 6 footer might be a little too much, but it might do it.
It's too much so it will depend upon conditions and the weight and aggressiveness of the disc.Will a L7800 pull a 6 foot cutting harrow.
I think our description of a harrow might be different.It's too much so it will depend upon conditions and the weight and aggressiveness of the disc.
If you have R-1 tires, your tractor is well ballasted, the disc is not too heavy and the conditions are light, you should be able to pull it but not well.
If the disc is three point mounted, you certainly will not be able to lift it without a full set of front weights.
SDT
