Radiator problem
rentthis
1,010
25
summerville,sc
As a last resort, I'm going to ask a non Kubota question. I have 2 10yr old Case 420 skid steer loaders that are eating radiators like they are free. I had both radiators blow out the top tanks within 2 weeks. I replaced both and they blew out within 2 jobs. I ordered 2 more from oem, did a block test and replaced both thermostats. Those 2 lasted a short time. I am now considering going Kubota. does anyone have an Idea what the crap is going on? I have over 2 grand in radiators and am looking at needing 2 more.
Brick Axelrod
L5460, BH92, RCR1872, FDR2572.RTVX1100c
Apr 12, 2018
135
9
South Carolina
Head gasket failure causing pressure build up in radiator maybe? Do a compression and leak down test.
10,685
Have you run it with the cap off to see if there are bubbles?
I had an issue like that where the overflow was plugged and was breaking plastic tanks.
Pau7220
Aug 1, 2017
785
280
Scranton, PA
There has to be a pressure relief issue in the system. Even if it is a bad head gasket, it should still vent before damaging the radiator tank. Is it in the radiator cap, or remote somewhere in the expansion/recovery tank? If there is an inter-mix issue with oil, the petroleum will turn the rubber gasket in the pressure relief to glue. It doesn't take much to cause problems. I have seen this issue quite a bit in the automotive industry (Ford Taurus), But in most cases it will crack the expansion tank or pop the weakest hose.
rentthis
1,010
25
summerville,sc
There were no bubbles in either radiator. I checked the expansion tanks and one of them was stopped tight. The other machine has a new expansion tank. The new tank replaced a broken tank. I am considering a leakdown test if I can find the tester. I can probably borrow one from Orielly auto parts. Do diesel engines have to be at top dead center to perform this test?
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
The majority of cylinder bore wear will be in the middle part of the bore,that’s where the highest forces from the piston will be against the bore
10,685
I would think a simple cylinder compression and radiator compression test should tell you a lot. ;)
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Interesting, I put my foot down flat out to pull into fast traffic in my 250ci ford wagon and saw a bit of "smoke" behind me in the rear view mirror. I drove up the road and turned off and idled around a trailer lot and the engine cut out/stalled. When I cranked, it was slow but started, I realized something wasn't right so I idled outside the gates, as it was about to close. Popped the hood, entire tank was split wide open.
I suspected a head gasket (common in this engine, had done one 100K miles previously, head bolts stretch) but put a radiator in it anyway. Found a slight leak down the side of the block from the gasket on the exhaust side, but very very slow, so I don't worry about it. But I don't floor it and hold it to redline anymore! I expect at full noise it may have been enough to blow through and pressurize the system faster than the cap could release the pressure. Certainly possible, but will probably never know, as it's not worth spending any more coin on.
