Thanks for welcoming me on board.
Have a small problem - well quite a large one really - with a B7001D acquired a couple of months ago with a flail mower to cut my paddocks. It had been working well, starting on first turn of the key and generally doing its' job well. Last weekend I used it for two hours cutting and put it away in a shed - all was well. Until I tried to start it again a couple of days later. Turn the key, oil pressure light up as normal, key to warm glow plugs and glow plugs warmed fine - turned to far right to engage starter and - zilch. Not even a flutter from the started solenoid. Lights working OK, indicators working OK, in fact all OK except apparently the connection to the starter motor solenoid.
Open bonnet (sorry, that's hood to you I believe as I'm on the other side of the pond ) and I find three disconnected wires laying there on the back of the panel. Honestly. Can only think that something vibrated free when I last used the tractor which didn't affect the running, but sure affected the starting. Two cables with female spade connectors one Blue and White and the other Red/Blue. Plus what looks like an Earth connector and a bolt hole that looks recently used. Now whilst I can find a bolt and put that back in place, I have no idea where the Blue/White and Red/Blue wires (which come out of the main loom bundle) connect to, as there no obvious place that they've come from.
I've attached a couple of pictures. If you have a B7001 could I ask that you have a look for me and let me know where these go please? Many thanks for your help.
John
John
