OK, I have to stop kicking tires and put together a final list. My gut tells me the B2650 is what to go with after much deliberation and based on the experiences of many others.
Quick refresh, this is primarily for grading sand and gravel driveway, plowing snow, moving dirt and mulch, knocking over some small brush (2-3" stuff), eventually getting a grapple to move brush, eventually getting a MMM to mow 3/4 acre with. Earliest needs are driveway maintenance and snow removal. I'll use the FEL to start with snow removal and see how it goes before looking into a front blade or rear blade. Will be getting a box blade, TnT, and adding two float detent valves (requires 3 valves total because first MUST be a double acting valve). Also interested in a Quick Hitch but not sure what is best suited for the B2650.
I'll update the list of items in this first post as I go, based on feedback from you guys! Just looking for a finalized list to present to dealers for quotes and want to make sure I'm not missing anything.
2018 B2650 Kubota Build:
Additional Implements, Hardware, Misc:
Questions
- B2650HSD
- ABR8742 & ABR8744 TURF TIRES (R3)
- BL7343 TWO SPOOL BANKING KIT
- BL7353 3RD POSITION VALVE MOUNTING KIT
- B7309C 1ST POSITION DOUBLE ACTING VALVE KIT
- BL7393 FLOAT DETENT VALVE (first float)
- BL7393 FLOAT DETENT VALVE (second float)
- LA534A FRONT LOADER PACKAGE
- B2366 MECH 2 LVR QUICK COUPLER
- B2356 60" LIGHT MATERIAL QUICK ATTACH BUCKET
- B7308A 3RD FUNCTION VALVE KIT FOR ROPS
- LP QH15 Quick Hitch
- Top and Tilt Kit
- LP BB2560 60" Box Blade
- Piranha Tooth Bar
- Insurance (Have to verify homeowner coverage, if not will go with Kubota coverage)
Questions
- Which TnT Kit? Fit-Rite has an 18 week wait time currently. Any other options you'd recommend? Any to steer clear of that a dealer might want to include?
- Which Quick Hitch do you recommend? Any to steer clear of that a dealer might want to include?
- Thinking about that Piranha Tooth Bar for the brush clearing work. Lot of soft held shrubs/brush in sand that should pull right out with ease. Figure this is perfect for that. Agree?
- Anything else I'm overlooking?
