2 bottom plow vs. tractor size
GEPM64
B2601 with FEL, Box Scraper, rotary mower, 3pt snowblower and Sovema Tiller
Sep 15, 2014
78
Hazelridge, Manitoba, Canada
Hi folks,
What are the chances I can pull a 2 bottom plow with my B2601? Is there a rule of thumb for tractor size vs. implements size particularly with ground engagement implements?
Thanks in advance,
Glenn
2,551
Hi folks,
Thanks in advance,
Glenn
somewhere I read .......1" - 1.5" per HP ......so a 14" single would need 14 to 21 HP at the drawbar
but it will depend on the soil and type of conditions too!;)
SDT
multiple and various
Apr 15, 2018
3,255
1,042
SE, IN
Hi folks,
Thanks in advance,
Glenn
No.
Pulling a 2X14 moldboard plow will require close to 30 PTO HP and over 20 drawbar HP in good ground and much more of both in many grounds. The tractor will also need to be properly set up for plowing, e.g., AG tires, ballast, etc.
Not sure what you plan to do but a rototiller may well be a better alternative.
SDT
GEPM64
Sep 15, 2014
78
Thanks everybody,
I came across a used one for sale for $350 and thought it was a good deal. I may pick it up anyways.
Thanks,
Glenn
5,566
If you want a nice one bottom 16" plow, find a scrapper who has the old pull type plow(usually two bottom). Remove one beam and make the 3pt arms.
Not much to a plow.
mbu
260
United States
Be careful about buying old plows. Moldboards and shears do wear out and you'll most likely never find replacements. If you do find an old plow that's in fair condition, make sure you hardface the wearable parts to make it last as long as possible.
GEPM64
Sep 15, 2014
78
I did not think of that. Thanks for the info. I don’t really need it, I just found it and thought it was cheap enough to add to the fleet.
Regards,
Glenn
