Pau7220
Here's where my story started..
http://www.orangetractortalks.com/forums/showthread.php?p=250663#post250663
After a thorough repair and rebuild, 50 hours later the snap ring shattered again, blowing the input bearing retainer off and dumping the fluid once again. Thinking I may not have cut the recess squarely or deep enough, I went on the search for a housing.
I was able to find a used housing (more on that FIASCO later), ordered another batch of seals and gaskets from Messicks, and did another thorough rebuild.
During final adjustment I noticed when turning the input shaft to the left (wheels go to right), the ball nut comes up and hits the bearing retainer. With the slightest amount of force with a small pair of vice-grips on the shaft, I was watching the snap ring flexing.... only imagining what it looks like with the force of hydraulics slamming up against it. Anyway, I figured I'd get the box put back on then try to figure out a solution, even though you can't see any part of the input end when it's installed.
After I got it back on, cleaned up, fluid back in and working properly... I noticed it definitely was overthrowing and trying to kill itself again. RF tire had also been hitting the loader valve to the point of the bracket being bent, and had the hoses abraded.
Trying to figure this one out before taking a bridge, I noticed the steering stops on the knuckles were quite worn, combined with a little play in the tie rod ends (the reason I drilled and tapped for grease fittings), along with a poor design.... I got it!! Now how do I fix it?
This is what I came up with. I found a piece of 1/2" x 2 1/2" , cut, drilled, fit to hit pitman arm, and spaced out with flat washers for adjustment. I had to cut the angle to clear the tie rods when the axle articulated. I set it so I could get my fist between the loader valve and the tire (after straightening the bracket). Now I have plenty of safe area with the pitman arm hitting the stop long before the ball nut hits the bearing retainer blowing the box apart. Now I know why it's the defunct "old style steering ".
