90’s model L2500 No 3 point lift HELLLLP!
Caillouet407
Kubota L2500
Jul 24, 2018
Sulphur, LA, USA
I just acquired a 90s models L2500, drug it to the house drained all fluids and got her running. 215 hours. The o my problem I have found so far is that the 3 point has no lift, no front loader so I don’t know if it’s a pump issue. I have drained hydro fluid cleaned the screen and replaced fluid. Hoping it would come to life but still nothing. Power steering works fine. Can hear fluid moving when I move control to lower position but nothing when I move it to raised position. If i lift it with jack and close the 3 point speed control knob it will not hold my finish mower up. Can someone point me in a direction?
5,396
2,082
Several possibilities and none are "easy".
Position control valve stuck/sticking. Pump weak. Leak in the cylinder/piston. Position control lever turning on it's shaft (sheared pin). Feedback link missing/broken/off/bent/out of adjustment. There's more but it'll give you half an idea...
Caillouet407
Kubota L2500
Jul 24, 2018
Sulphur, LA, USA
Well good news, since I could hear fluid trying to move I decided to idle it up and just work the valve back and forth. That did it. 3 point is working fine and holding a load. Looks like the valve was just needing to be exercised and probably was plugged up. I’m gonna run it for 25 hrs and change the hydro fluid again as well as screen cleaning.
MilkyWay
181
11
Dahlonega, GA
Working like a champ.
Welcome to the forum!
Judging from the picture, you must live in the southern hemisphere? :D
We, or at least some of us on site don't take everything too seriously so please don't take immediate offense. All who need help get it here, so Just roll with it; and again welcome.
Jim@MilkyWay
