M4500 & M4500DT tire pressures
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
447
94
NZ
My operator's manual doesn't say what tyre pressures should be used. Weird. However the Workshop Service Manual has the info. So for those without a WSM, I hope this is useful:
"For usual works except for front loader work
Front tires
6.00-16-6PR = 340 kPa 48 psi (M4500 and M5500)
7.50-16-6PR = 280 kPa 40 psi (M4500, M5500 and M7500)
8.3 -24-6PR = 220 kPa 31 psi (M4500 and M5500)
9.5 -24-6PR = 160 kPa 23 psi (M4500, M5500 and M7500)
11.2-24-6PR = 180 kPa 26 psi (M7500)
Rear tires
14.9-28-6PR = 120 kPa 17 psi (M4500 and M5500)
16.9-30-6PR = same (M5500 and M7500)
18.4-30-6PR = same (M7500)
"For front loader work keep the pressure of the front tyres shown below.
6.00-16-6PR = 350 kPa 50 psi
7.50-16-6PR = 280 kPa 40 psi (same as non-loader use)
8.3 -24-6PR = 240 kPa 38 psi
9.5 -24-6PR = 200 kPa 28 psi
11.2-24-6PR = 180 kPa 26 psi (same as non-loader use)
The above will be for bias ply tires.
JerryMT
Jun 17, 2017
529
153
The Palouse - North Idaho
Front tires
Rear tires
16.9-30-6PR = same
18.4-30-6PR = same
Thanks for posting this. I replaced the front and rear tires on our M4500 in December. While plowing snow I kept slipping-poor traction. I measured the tire pressure on the loaded rears and it was 27 psig. These are radials and they didn't have the characteristic bulge. I found the chart at the tire manufacturers web site as a function of load and dropped the pressure to the teens. Traction greatly improved.
JohnDB
Jun 9, 2018
447
94
NZ
Good point JerryMT - the pressures from my Kubota WSM would be for bias ply tyres. I hadn't thought about radials.
