How do you sharpen the bladesign on your brush hog?
Take the blades off and sharpen them with a flap disc on a 7” grinder.
I have tried to take the blades off with no success. Asked the Kubota guy how they did it and he said they just tilted it and used a hand grinder so that is the way I did it. It would be nice to get those blades off, may do the heat and impact deal if I have some spare time. I was afraid I did not get them sharp enough but according to the other poster I think I got them just right.
If you get them sharp like a lawn mower blade, it can cut sapling off and they will be sharp enough to puncture a tire. A blunt edge will “shatter” the stump so it won’t be sharp.I was told by my Kubota dealer to also not bring them to a sharp point but rather leave the edge rounded off like a #2 pencil. If you put a sharp edge on it, then it will get beat up and ruined going through heave stuff, saplings, stumps, ant mounds (my favorite)etc...
I have not looked at removing them from my Woods brush hog, but need to get on them this spring. I may try leaning it against a tree and hitting it with an angle grinder
Unlike most, I keep the blades on all 4 of my rough cut mowers sharp lake a lawn mower. Cut is better, mower takes less HP and tractors use less fuel.How do you sharpen the bladesign on your brush hog?
I pick it up with the FEL, grinder the rough stuff off, then sharpen with die grinder & 40 grit pads for grass,etc. For heavy cutting (brush up to 3") just the grinder. If that stick in the picture slips, we'll assume you quit the forum!How do you sharpen the bladesign on your brush hog?
