I have a Dodge diesel with an 8’ fisher plow, a walk behind snow blower, a Simplicity 4x4 tractor with a snow blower and my Kubota with the back blade and now a SSQA mounted Fisher snow plow. I find in thawed ground using the back blade backwards works well even over finished lawn where my snow piles are made with much less spring cleanup and repair.
I made my own snow plow for my L3901HST w/3rd function. I’m too cheap to spend the dollars to purchase one already made and I need projects to take up my spare time.
I acquired a well-used 7-1/2” Fisher snow plow from my son’s friend for zero dollars and removed the pusher brackets from an old 1970 Scout I have. I attached it to a Titian SSQA plate, added some scrap steel, fasteners and some welding. I purchased two Hyd hoses, quick couplers and pins for a total expense of about $225 bucks. I made the plow assembly with a stiff hitch for back dragging, pull the pins and it fully floats.
There it a learning curve, some instances the tractors loader float functions works well, in others it does not. I find the more forward tilt I have to scrape the surface the more the float function does not work well. The float function seems to work well while angling the plow since the cutting edge is covering more forward travel distance, rather than parallel to the direction of travel. Soft earthen driveways are and issue with every mode of snow removal, before spring comes I am going to modify the disk shoes on the plow to triple there foot print in an attempt to float the plow on softer ground.
I always push the first passes straight to the end then I finish by angling the plow to clean up the spillage and edges. Front chains may help the front end from skidding but I also plow a paved drive and do not want to damage the coated surface with chains.
