Play in front axle B7100hst d
dlumpy5282
38
Indiana
When moving steering left to right the front axle will move back and forth on the pin about a 1/4 inch and I don't see shims listed for it. any help appreciated
asbug
B7001 - looks orange to me... Woods 5' scrape, 42" rotary cutter, shreader/chip.
Feb 11, 2011
155
Varnell,GA - USA
Funny,
I just looked at mine this weekend and it does the same thing, just not as much movement.
I am thinking some thin bronze washers/shims, that way if it binds, it could mash out the bushing...
KC
asbug
Feb 11, 2011
155
Varnell,GA - USA
Was just looking through the owners manual on this and it appears that all one would have to do is tighten the bolt and reinstall the locking spring for the pivot.
I'll get to it one day...
KC
southerner
L2800DT, B6100 HST, 5' Modern shreader, 5' and 4' box blade, 5' and 42" tiller
Aug 28, 2011
Magnolia, TX
I have the same problem in my B6100 HST, but I can't find out whether this is a problem on not. It would be nice is VIC would weight in on this subject.
Thanks.
Brian.
jethro210
B5200E
Jan 31, 2013
11
Oklahoma
I have the same problem with my B5200E. Half the play in my steering is coming from the axle moving forward and backwards. I was going to pull the pin to measure it and try to find a hardened shim so it wont wear out so fast.
11,278
Replace the bushings that are in it would be my 2 cents?;)
jethro210
B5200E
Jan 31, 2013
11
Oklahoma
Kubota parts diagram does not show any bushings available in the center pin area. Guess I will have to install a shim. Anyone happen to know what diameter the center pin is?
11,278
Bluegill, T
The front pin on a B7100 is lubed by the oil in the front end, no grease zerk needed.
jethro210,
There are 2 bushings in the front end.
Morgan44
38
Walton KY USA
I also had this on my b7100. I added a large washer and tightened the nut with pin to take out the play. It still leaks a very small amount of oil though. I want to replace the o rings and bushings but, it's going to be a little bit of a job. From what I can tell the whole front end will have to be dropped because the oil pan is in the way of pulling the pin. Anyone see it differently?
11,278
Then you would be looking for a diagram for a HST-E (2wd) not a HST-D (4wd).;)
And yes you would be right no bushings.:p
To get rid of front and back play on those just shim it with a washer.:)
