Ground prep question
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
I have:
Single tine ripper
Box scrapper with rippers
Landscape rake
Rear blade
Front blade
FEL and BH
My question is what is generally the right sequence to rip and prep virgin ground that is full of ruts and ridges for new lawn seed?
My thoughts is to use the box scraper for general break up and general moving of material. Followed by the landscape rake for rocks. Followed by the rear blade for touch up and minor grading. Followed by the landscape in order to create the troughs for the grass seed to lay. Am I close for this project?
Thank you in advance :)
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,200
2,870
Near Lancaster, PA, USA
We seeded a bit over an acre to enlarge our yard 5 years ago. First I killed the weeds and then raked the dead stuff, old cornstalk remnants, etc. Then ran the box blade all over it, followed by the landscape rake. I had another drag that is made of a pair of I beams that was used in some spots. The biggest help were the box blade and the landscape rake. When the ground was shaped about right, I set the wheels on the rake so it wasn't dragging hard and the rake was angled. This made gathering and removing the stones easier.
First picture is the south side of the creek. Work on that side was just started in this photo, and the piles are excess topsoil from the north side that I FEL'd to this side of the creek to fill in some low spots.
The other two are fo the north side. This is before the final rake/seed operation. Middle picture is a wider view of the north side, and the last picture is a closer look a the north side.
Kubota_Man
Dec 25, 2010
953
Kellogg, Idaho
Thank you kindly. I can only hope that my project ends up as well as yours.
bearskinner
Sep 1, 2014
926
242
N. Idaho
Just a few pics of clearing, fencing, and leveling and seeding a 3/4 acre dog run area.
Started by limbing up all the trees we were keeping. Cleared away many undesirable and thinking some areas. Backhoe out all the extra stumps, then raked up pine needles and twigs.
Used the Piranha on the FEL to knock down and fill the large high and low spots. Went to the big tines, on the excavator attachment. That really ripped up the surface, weeds, roots etc.
Final rake with the landscape rake, ran a throwing seeder thru the area with a good Forrest mix, as there’s lots of shade. It took a couple months to really fill in fully, but was really beautiful after 3 weeks. With constant mowing, water and feeding, all the weeds ( including the dreaded knapweed) are gone and you can walk around barefoot. A bit it work and sweat equity, you will have a beautiful lawn
Kubota_Man
Dec 25, 2010
953
Kellogg, Idaho
Thank you kindly
Yooper
3901 LA525
May 31, 2015
1,721
890
NE Wisconsin
Chim, bearskinner, that is impressive work! Did some work on my property last year and found out I do not have a good eye for leveling dirt. Maybe I am not level headed enough.:D
10,713
Me neither! :p :D
This is the foundation pad for our new house, it was leveled within inches across 100' with a simple land place, they work wonders.
10,713
I made this out of some scrap that was hanging around, I beams are from an old small single wide trailer, and the cutting blades are AR 500, in 3 years of use they show no signs of wear.
