Ok here is one way to get it exact without having to pull the motor apart at all.
You would set up a boring rack and bar and use the motor like a lathe, run it a bore the hole into it.
It's fairly easy tool to make and operate.
If you need more info I can sketch it up for you.
EDIT: Russell has a good idea too! He was typing as the same time as me.
