My m5500 is locked. It has been sitting idle for a few months and now will not turn. I have disconnected external hydraulic pump and applied 36" wrench in effort to break loose --- no luck. I removed starter to see if it was locked. No problem with starter and still could not turn engine with wrench with starter off. I have removed injectors and inserted mixture of atf and acetone. No improvement after 3 days. I have jacked up rear and rocked the tires --- still no change.
The only problems I have had in the past was rusty starter that required clean out of water and rust and a pto clutch that would not disengage. Obvious water getting into clutch/starter/flywheel area due to stuck pto and rusty starter.
Anyone know of anything else that would lock engine?
would 3pt hydraulic pump cause this issue?
Would Pto or engine clutch sticking cause this problem?
I am stumped and would appreciate any suggestions.
thanks
thanks
