worklights
DigVT
L3010
Jul 7, 2017
Peacham VT
Any suggestions for a reasonably priced, easy to install work light kit, attached to ROPS? Is there something that would cast light forward and in reverse? I have a work light fuse on a L3010, so I am hoping it's somewhat straight forward. Thanks
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
Doesn't get any easier than using a harness like this...
https://www.amazon.com/gp/product/B00WMPGLYU/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1
That one is for dual lights, there are also single light harness' available.
Just pick you actual lights and mount them and wire it up. Easy Peasey
I've been using one on my Jeep for my 20" light bar for 2yrs now and am installing the dual light harness on my B8200 for two 3"x3" LED's that i'm mounting in place of the running lights on the rear fenders. I like that the switch lights up red when it's powered on.
bearskinner
Sep 1, 2014
926
241
N. Idaho
The price of LED’s has come down to nothing. Look on EBAY or Amazon for light bars, many have optional wiring harness you can purchase. Crazy lighting for working in the dark
Hillbilly77
39
New York
I put Auxbeam LEDs on my L4310. They are very bright and inexpensive.
I used the flood lights, not the spot lights. They're available on Amazon for $21 per pair.
I installed them on the ROPS & on the brush guard. I ran my own harness to the ROPS. I used the factory low beam headlight circuit for the front lights.
Here is the thread I started about the ones on the front:
http://www.orangetractortalks.com/forums/showthread.php?t=30947
Here is a link to the lights on Amazon:
https://www.amazon.com/s/ref=nb_sb_...+bar&rh=n:15684181,k:auxbeam+led+4"+light+bar
EDIT:
Here is an entire thread here with lots of good ideas for installing lighting on ROPS.
http://www.orangetractortalks.com/forums/showthread.php?t=23686
Kingcreek
Grand L3010 GST 4wd, LA481FEL, various attachments and accessories
Aug 3, 2011
457
NW Illinois
I put 2 ironton mini LED floods for rear facing work light and a northpole 23" LED combo spot/flood light bar on the top of the ROPs.
We could almost have a subforum devoted just to lights and wiring.
Dchemphill1
L3901HST, brush hog, L525 loader, rear blade, forks and bail spike
Jun 9, 2016
110
46
Fort Calhoun, NE, USA
Try ropslights.com
Let them know the tractor you want lights for and they will have wire harness ready to plug in. You just mount lights on rops bar. I got two facing forward and one rear facing two switches. Lights up the road or objects incredibly well. They are LED lights.
hockeystewey
2017 BX1880 w FEL, 54"MMM, 2019 BX2816 50 " snowblower
Dec 12, 2017
117
NY
Try ropslights.com
Dchemphill1, I am about to order a set from ropslights.com ..... I am stuck between 3 or 4 lights, do you regret only having 1 reverse light by any chance? Thanks for the help....
Dunbar
L2501 LA525 QA PFL2042 Forks RCR1860 FDR1672 BB1560 EA55 WR Grapple FitRite TnT
Aug 2, 2018
217
I pondered your question on 3 or 4 and decided 4. Backing is just as important as forward. I'm more worried about bashing my rotary cutter into something than my FEL. I ordered from ROPS Lights without even shopping the other links in this thread. It's worth it to me to have someone build a plug and play kit and that they stand behind. If I got an eBay dead on arrival light the hassle would not be worth dealing with to return. Same with harness. Kudo's to ROPS lights for offering custom kits for each model Kubota.
John T
2017 BX23S
May 5, 2017
1,129
622
under a rock
To much of a good thing starts to look ridiculous in my opinion.
SidecarFlip
Banned
562
My tractors came with Halogens up top and I took them off and replaced them with IP54 rated CREE SMD sealed LED's from Super Bright LED .com I need the light when roading after dark and in the fields when farming. 700 lumens per unit and visibility to 1/2 mile.
My personal opinion is light bars look tacky.
Jchonline
599
Red Feather Lakes, CO
This is my next mini project for the M62. I am going to replace front and rear lights with LEDs. Next time I am at the property I will get the measurements for the brackets.
Dchemphill1
Jun 9, 2016
110
46
No regrets. Have not wanted another reverse facing light. Happy with my setup.
Ikc1990
Kubota m125x, m9000, b2710, and other equiptment
Dec 2, 2020
292
130
Vermont
I ordered a set on amazon with 2- 4 inch 6 LEDs and 1 -20 inch led I put 20 inch on top of my Curtis cab frontwards and the 2 small on back of curtis cab every thing is adjustable and hangs under cab so dosnt interfere height wise going in and out of barn. It was 56 bucks for the lights, brackets, bolts, wiring harness including switch, fuse and relay plug and play kit.
doublebass73
L2501F, 68" Pull Type Snowblower, Spreader, Dirt Scoop
Oct 7, 2020
105
112
NH
FYI I ordered the 3 light kit from them almost a month ago and still haven't received it. It's not really their fault but they use the Canadian postal service who is running ridiculously slow right now. I check the tracking number everyday and it still just says "delayed" with no estimated arrival date. It won't tell me where the shipment is either.
