I'm having an issue with my B8200 ( clutch, D950 ).
When I try and start the tractor, the fusible link starts to get hot and smoke. ( I stop before it burnt out completely )
I think that if I were to replace that fusible link, the same thing would happen with the new one.
The question is : The fusible link seems to protect everything on that side ( the key switch and everything it is connected to ) so how can I figure out what the REAL problem is ? I've replaced the key switch already because I thought it was bad, but I'm still getting the same symptoms.
At first, I was receiving 12v at the key switch through the red wire, and then, when I would simply turn the key to the RUN position, the voltage on that wire would disappear. I cleaned up the battery ground to the rear axle, and then I cleaned up the starter solenoid nut and ends that both attach there ( the battery positive cable, and the red wire which carries power to the ignition switch ). After doing that, I am now getting power to the key switch when I turn the key to the "RUN" position. But now ( as I said ) when I try to start it, the fusible link gets hot and starts to shoot smoke out of a hole it has burned for itself in the link wire cover. ( The starter does not turn over at all like this ... I've tested and jumped 12v directly to the starter itself and it will turn the engine over ).
Is there something on one side or the other that would be causing this ? The starter solenoid ? The voltage regulator ? Is it simply a bad fusible link that needs replaced ?
I'm just not quite sure what to test or change out.
Many many Thanks.
Many many Thanks.
