Down to one of the last issues with my rebuilt engine. I cannot get the ticking sound out of my engine despite adjusting the Lash to 0.007in.
The engine also generates vibration after about 1500 RPMs. Was hoping that both these problems would be less after the rebuild but they never went away. I adjusted the valve lash this way. Could you please confirm that I am doing this right:
1342
4213
When both the intake valve and exhaust valves are moving on cylinder 1 indicating end of exhaust start of intake I can adjust lash on the intake and exhaust valves on cylinder 4.
When both valves are moving on cylinder 2 I can adjust both valves on cylinder 3 and when both valves are moving on cylinder 3 I can adjust 2 and when both valves are moving on cylinder 4 I can adjust 1.
I have very little blow by coming out of the blow by tube and the tractor is still blowing Blue Smoke. Not that much especially if I give the tractor a workout in my yard but it is still puffing smoke. I have JD 10W30 brake in oil in the tractor and will be leaving it in for a while
Unless you guys determine that I am not adjusting my valves correctly I am afraid that I might be running on low oil pressure.
I did not change out my oil pump wondering if the v1902DIA engine is prone to this.
I do not have and oil pressure gauge. Will be buy a quality stainless 3 gauge kit so I can monitor oil pressure voltage and temperature
I did see that someone did and oil pressure gauge on Ott
And as usual thank you very much for any comments, concerns or ideas you may have
1342
4213
