Hi All ,
I have just purchased a new BX2680 with FEL, drive over deck, front mount snow blower and rear tiller. The front end will have the new K-Connect mount for the snow blower and any other Kubota attachment.
Im looking at making a hydraulic wood splitter. I Do Not want to run it off the tractor hydraulics, not enough flow, I think just a bit more then 6gpm at 2000 rpm motor speed.
I have other tractors, and run a rear PTO hyd. pump and they work ok, but you still need to get the PTO spinning at 540 to get any kind of decent flow, unless of course you have a monster sized pump....
Im thinkin of using the mid PTO.... Spins at roughly the same speed as the engine, so one could run a hyd pump at much faster rpm, say 1200, with the motor rpm roughly the same.. The BX 2680 has more then enough power to drive a 15 - 20 gpm pump at 2500 psi... So why not use the mid mount PTO>>>
Any thoughts on this would be great. Merry Christmas and Happy New Year to ALL!!
