Hi folks, just signed up this evening. I have an M125 with stripped splines on the front differential pinion gear that joins to the front propeller shaft. Got the new parts and removed the front axel from the tractor. Got the bolts out of the pinion bearing case, however the pinion bearing case does not come out. Looking at the parts manual it has an attached bracket that the front axle shafts and beveled gears run through? My question is, what steps need to be taken to remove the pinion bearing case so that I can change the pionion gear and bearings etc. Thanks in advance.
