rbargeron
Attached is a clearer drawing of the hydraulic block labeling its ports and selector valve. I'm also posting the other drawing again so toggling between them is easy.
When no loader is present, the hose on the block we're calling the bypass connects from the "out" to the "in". When a loader is mounted, the bypass hose is disconnected from the "out" port and instead connects to the short hose from the valve. The other two hoses connect to the "out" port and the "tank" port (forward end of the block). This should be the setup you have if your tractor isn't modified.
Hope I've described it right - pictures of my L3250 don't help - it has an additional valve and hoses so it's too crowded to see. Dick B
