Our Kubota is normally on gravel under overhang behind garage. Took the mower deck off, moved into garage to prepare for snowblower attachment, and I noticed the right rear wheel was leaning in.
After looking in the manual and online here, figured out both side clevis pins sheared off, left side was just slid over a little, bought clevis pins at the hardware store, managed to retighten the left wedge clamp.
Right side was slid all the way in, managed to slide out, install clevis pin, could not budge the bolt and nut on the clamps, although the clamp was loose. Brother in law who is a service tech at a car dealership came over and we got the six wheel lugs off, broke the socket on the last one. Wicked tight.
Slid the hub off. I'm pretty sure that hub is toast. Took picture of axle, assume that is ok? This has 33x12.5 wheels, dealer said hub is different depending on wheel size?
Should I get official Kubota hub, or are the ones on ebay fine, and will it fit my wheel/tire?
Thanks,
Paul
Thanks,
Paul
