Finally an update.
I did end up moving the valve over to the right side. Even though there is physically not as much room than there is on the left, based on the required configuration of the valve, it fit better on the right.
The 3 pt supply I ALMOST had... The threads are a size 6 BPP. I got that fitting locally... But there just isn't enough available height to squeeze a 90 on top of the threaded fitting. And there isnt enough room to spin in a 90... So unless I find something between now and tomorrow when I have the hoses made, it'll have to be the Kubota fitting.
I was able to thread in a SAE 8 90 x female pipe thread into the power beyond on the loader valve, which does eliminate the fitting from Kubota AND pulls the fitting in closer to the frame. I did have to loosen the loader line just behind it to thread it in, but no issues otherwise.
Sent from my SM-G892A using Tapatalk
