I can't offer any facts about that, but my experience has been that it occurs at temperatures below about 10 degrees F.At what temperature does the possibility of gelling take place?
Thanks, if so I don't think I need to worry about that. But just in case, any idea how long a shelf life that additive has?I can't offer any facts about that, but my experience has been that it occurs at temperatures below about 10 degrees F.
I buy it in gallon jugs from the local Tractor Supply store. For my use that lasts me about 5 years. I haven't had any problem with it.Thanks, if so I don't think I need to worry about that. But just in case, any idea how long a shelf life that additive has?
Great! Thanks! I think I'll get some just to be safe. I need to take a couple cans over there anyway for some "red fuel".I buy it in gallon jugs from the local Tractor Supply store. For my use that lasts me about 5 years. I haven't had any problem with it.
It varies but summer blend fuels can jell as high as 28°FI can't offer any facts about that, but my experience has been that it occurs at temperatures below about 10 degrees F.
I run Power Service in all my tractor fuel year round, but I once left a small glass bottle of untreated summer blend outside overnight at 25 degrees F and could see a little waxy build up at the surface the next morn. It was gone in minutes after the sun hit it, but that was enough to convince me it was better to be safe than sorry.It varies but summer blend fuels can jell as high as 28°F
If you read a Kubota owner's manual carefully, after getting the engine started there is a significant period it should run at a high idle. The amount of time depends upon the outside temp.Thanks for the feed back guys, I will probably just but the block heater from the dealer to be safe but like the last gentleman said the rest of the tractor (driveline/hydraulic wise) is still ice cold.
- Jake
I had wondered if there was a summer/winter blend and was going to ask!It varies but summer blend fuels can jell as high as 28°F
At temps of 60 and above do you think 1 minute is sufficient? Actually if I'm putting on a nearby implement I'll use LOW range to position it then let it run. I did read that chart before but I didn't remember the "half throttle" part. I'll probably still let it go a minute at 2K then half for just a few minutes. It isn't often it gets very cold here.If you read a Kubota owner's manual carefully, after getting the engine started there is a significant period it should run at a high idle. The amount of time depends upon the outside temp.
Dave M7040
I do the same thing. MUCH better to be safe than sorry.I run Power Service in all my tractor fuel year round, but I once left a small glass bottle of untreated summer blend outside overnight at 25 degrees F and could see a little waxy build up at the surface the next morn. It was gone in minutes after the sun hit it, but that was enough to convince me it was better to be safe than sorry.
